Land_Yachters's avatar
Feb 02, 2022
Jeep GC diagnostic plug and AF one braking issue
Hard to say what I needed in subject line. Have had 2018 Grand Cherokee towed behind my Tiffin for over a year and about 18,000 miles. No problems with Blue Ox hardware and Air Force one braking. One of the service lights came on in car (service stability control), made appointment at dealer, and he said he couldn't hook up diagnostic cable to see what the issue was because it was blocked by the brake hardware installed on pedal. He said that would be an issue on any service required and not having diagnostic readings to go on. I left and will call shop that installed the system, but was wondering if anyone has had this issue. I think the Jeep/GC and Air force One combination is pretty popular out there.
Thanks for any guidance.
  • Sounds like a bad install. Perhaps install on the other side of the brake pedal or see if there is other hardware to solve the issue. I'd want a much more experienced person to correct and check the entire system for potential problems.
    As a last resore take pictures, mark the cylinder location with tape and then remove it for your service.
  • They just installed it in a bad place, most likely over top of the diagnostic connector in the JGC. That connector is under the dash to the left of the steering column.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
