CA Traveler wrote:
For me I can accept that the dealer has to install "something" to make the vehicle flat towable.
But I would not accept a condition like "disconnect the negative battery terminal". Since a flat towable vehicle cannot be backed up it's enough should a quick disconnect need arise without having to open the hood, find a wrench and reconnect the battery cable.
Very simple fix for THAT: install a battery disconnect switch on the toad. Don't even have to open the hood, although simpler install if you do put it under the hood.
