CarnationSailor's avatar
Sep 02, 2017
Keeping Mice Out
Been working on sealing up any openings in the underside of the trailer that mice could use to get in. I've sealed up numerous gaps between the frame and the coroplast panel. I still have two openings in the I-beams where I'm fairly sure that mice have been getting in and I need ideas for preventing entry.
The left and right side I-beams each have one oval hole (about 3" x 1.5") where the slide-out's hydraulic actuator rod passes thru. I've been plugging up the gap with steel wool wrapped in a dryer sheet each time we put the slides out and whenever I put the unit in storage. This works, but I'm getting tired of the procedure and am looking for a permanent solution.
I've been thinking of a boot-like cover that, at one end, would attach around the hole with velcro, and have a hole in the center of the other end for the rod to pass thru. Maybe made out of rubber or leather.
I can't use a rigid plate with a hole in it because the rod's position relative to the sides of the hole is different when the slide is in compared to when it is out. (The rod needs to be able to move up/down and left/right in the opening as the slide is actuated.)
I've spoken with Crossroads as well as Lippert, but they had no ideas. I thought that maybe a higher-end trailer might come with an appropriate cover for the opening, but apparently not so.
Has anyone come up with a solution to this problem?
  • stickdog wrote:
    Only go to well manicured RV resorts that have rodent control. Or as we do have the sticky traps out all the time.
    LOL!
  • donn0128 wrote:
    Might shop online for bellows and see if you can find one that would work. Places like Grangers.com usually have a lot of choices.
    I gave up searching online before posting, but I did follow your suggestion and tried Grainger.com, but no luck. I think I need some sort of DIY solution.
  • Dennis12 wrote:
    We live in the country and this time of the year we always mice getting into our house. The wife came home last year with these Victor plug in's. I laughed at her and said money poorly spent. We'll the joke was on me. She ask me about every week if I seen that mouse. When i say no she says neither have I, and laughs.
    Read the reviews on them
    I checked the reviews on Amazon (3 stars) - not exactly an endorsement.
    Also, they require 110 volts which I don't have at my storage yard nor when I'm dry camping.
  • We live in the country and this time of the year we always mice getting into our house. The wife came home last year with these Victor plug in's. I laughed at her and said money poorly spent. We'll the joke was on me. She ask me about every week if I seen that mouse. When i say no she says neither have I, and laughs.
  • Only go to well manicured RV resorts that have rodent control. Or as we do have the sticky traps out all the time.
  • Might shop online for bellows and see if you can find one that would work. Places like Grangers.com usually have a lot of choices.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 15, 2026
