Anmacc2's avatar
Anmacc2
KISS Keep it simple s..... Rant
It seems to me that there are some people who are bound and determined to make things as complicated and difficult as they possibly can under the guise of "safety" and "efficiency". They try to push the philosophy that if you're not workin your butt off at it then you're not doing it right OR that workin your butt off by constantly working will save you work in the long run by doing a ton of work you didn't need to do in the first place to prevent work you probably wouldn't have had to do anyway. :R
It's an RV! Recreational Vehicle! Put your stuff in it and keep it there. Don't keep adding more stuff. When you're ready to use it put in your perishables and food, hitch it up and go! Once a year give it the good once over and give it what it needs. Each time you use it walk around it and give it a visual. Check your tire pressure now and then. How hard is that? In fact, the more often you use it the better it is.
Bigger is not always better. More stuff doesn't always mean more fun. Making it more complicated doesn't always equate to making it more efficient or safer. If you set it up right the first time there is no reason to recalculate or readjust every time you use it. You don't need to hit the scales, measure your wheal wells, check your levels and angles once you get them right. They don't magically change.
Watch out for idiots and fools as well as workaholics and worry warts.
Rant is over. Thanks for listening.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
