mickey48's avatar
mickey48
kitchen faucet
Has anyone replaced the standard kitchen faucet in there rv with a home kitchen faucet? any special fittings needed.?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Yes and .... perhaps.
    In my case the "New" faucet coded the hot and cold lines by "long and short" so I had to add a bit of flex hose to make it all fit..
    But normally NO, nothing special needed, they are standard off the shelf faucets or knock offs made more cheaply. I changed brands (The original was a Delta immitation) which is why I had to adapt.
    Yes on 4 different trailers...no special fittings.
  • I replaced more than just the leaky faucet the fiberglass sink was showing its age. DW said if your going to change it I want one like in the house, a composit granite. Had to enlarge the hole for the standard size sink and reinforced the counter top. Happy wife, happy life.
  • My travel trailer has a very thin metal, stainless steel kitchen sink. I replaced the lousy oem faucet with a single lever type faucet. It works perfect, but the action of lifting on that lever actually flexes the entire back of the sink. If I have to do it again, I will figure out a way to stiffen that area.
  • I have replaced the kitchen fixture in my last two motorhomes. Both of them required adapters. No problem, just a standard brass fitting.
  • As I have posted before. Finding a replacement faucet is easy. Just make sure the centers are the same. Installing it in an RV requires a 20 year old body with 50 years of experience.
  • No special fittings needed. The only problem can be lack of area to work in, but that is a problem with any faucet you put in. We did kitchen and bathroom with stuff bought at Home Depot
  • I have replaced my bathroom faucet with one from Lowes. There are no special fittings involved. It should be the same connection as any residential faucet.
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 02, 2026
