Tvov
Jun 04, 2016Explorer II
Another thing to look for is decent threads on your hoses and connections. The white hose I got from Walmart for drinking water works, but I have to be very careful screwing it on as the threads are so minimal that it will cross thread very easily -- and leak.
Elbows and connectors, get ones that have deep and sharp threads.
Many times when you see hoses laying next to each other in the store with different prices, it is very easy to just grab the cheapest one. I bet if you look at the ends, the more expensive hoses have good, deep threads in their connectors.
I've bought a bunch of screen washers for my camper's water connections. These are the washers with a screen built in. A little scary when I see the stuff that is sometimes caught in the screens - dirt, rust, jelly blob stuff...
If a connection is leaking, first thing I check is if it is cross threaded. Only after that do I check to see if I need to tighten it anymore. If still leaking, I disconnect it and check the washer - replace it if it is at all worn. Also! Does the washer fit snugly? Try a different washer. Even washers that come out of the same package can be slightly different and fit differently.
STILL leaking? Stop what you are doing, go around to the other side of the camper, call the wife to get you a beer, and spend the rest of the afternoon in a camp chair.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
