ChuckSteed
Jul 06, 2022Explorer
The Dometic 310 is far far better than any Thetaford toilet .. ever..
Since yo7 have replaced the flush valve I would look at the pedal assy to see if it is binding up when the toilet foot pedal is pressed down to flush the toilet..
If either the foot pedal is sticking on the side OR the inside bowl seal or flush port is sticking then it will not let the pedal return t9 proper position and will keep the plunger on the flush valve partially depressed..hence the flow of water
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
