ktmrfs
May 08, 2019Explorer III
mobeewan wrote:
Diesel fumes venting from a fuel can are not volatile like gasoline. It ain't gonna blow up your rig. I remember when I had a diesel Isuzu pick up. Periodically I had to drain the fuel filter water separator assembly.
The first time I had some cardboard and personal papers to burn. I poured the drained fuel into the barrel wetting the paper and cardboard. I stood back and flipped lit match after match into the barrel expecting the whump of ignition and the barrel to shake. Nothing. I finally grabbed a piece of paper with diesel on it and lit it with my lighter. A small spot lit not much bigger than the lighter. I watched as the flame very, very, slowly spread and threw the paper into the barrel, again nothing. I looked into the barrel and nothing, no flame of anytime, only a smoldering piece of paper. Throwing the paper in blew out the flame. I grabbed a piece of cardboard, lit a dry spot which burned faster, held the cardboard so the diesel fuel would ignite and waited till it started burning good. Then slowly I added the burning cardboard into the barrel waiting for the explosion and the fast run to the faucet to put out my engulfed limb. It didn't happen the flame slowly spread through the cardboard and paper. The flames spread and grew faster only as the heat warmed the diesel fuel.
Diesel fuel doesn't go bang or whump unless it has pressure or heat to help it.
The next time I added a couple ounces of gasoline to the burn barrel just for a little excitement.
Until you get diesel liquid above about 125F there aren't enough diesel vapors to ignite, nor keep it burning. Same with oil. Once tried to use some old bottles of unused engine oil to start a fire. Nope. Now drained engine oil, another story. Even in new vehicles it will have enough (doesn't take much) other low vapor point byproducts to get it burning.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
