Darryl_Rita
May 02, 2023Explorer
theoldwizard1 wrote:rhagfo wrote:
Well we built our own with correct ends for 50 amp cable. The cable is 6/4 SOOW electrical cable. It is rubber insulated rather than PVC. Stays flexible even below freezing.
6/4 SOOW cable
There is no need to use SOOW cordage ! It is rated for 600V. SJOOW is rated for 300V. Also rubber insulated.
Depending on the length, you probably only needed 8/4.
Thus the comments on the weight difference. SOOW is going to be heavier than SOW, and 6/4c heavier than 6/3c 1/8, and even a bigger difference than 8/4c.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
