John___Angela
May 02, 2013Explorer
This may sound dumb but when you open the slide is the out and in reversed. eg does the slide go out when you push in and vice versa? If so your cables may be reversed. If not, they may have been reversed briefly at one time and the two 40 amp fuses are blown. No worrys if that is the case. Just change them and continue on.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 16, 2026
