tpi
Jun 30, 2014Explorer
Maybe..
You have to determine what isolates the house 12 volt system from the vehicle 12 volt system. Some have diode, others have relay, and some may have a switch or no isolation at all. The diode would be problematic for backfeeding.
My class C uses a relay which clicks in when ignition is on, connecting the two systems. Getting engine started, then start generator and power converter should work. Probably best to operate least amount of vehicle accessories possible. I'm counting on it as a backup to alternator electrical failure.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
