BigRabbitMan
Jul 02, 2014Explorer
chainegang wrote:
As a further enhanced solution to my previous post, couldn't I use the gen set to charge the house battery which is connected to the isolator, but does not go any further. This set up allows the isolator to direct the current from the alternator to where it is need the most. If I jump the isolator by bridging the house battery posts to the engine battery posts, wouldn't that power up the engine battery in the senerio I described?
Yes! In my coach I have added a heavy duty switch to connect the two systems. I have been in your situation (twice!) and with the hard wired jump connection all I had to do was go turn on the normally open switch and away I went. Traveled from Cheyenne, WY to Minden, NE that way. No limping to it!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
