Oasisbob's avatar
Oasisbob
LIQUID SHINE PRODUCT?
Last year there was discussion of a liquid product for fiberglass RV finish's that worked well. I was reading labels at Home Depot thinking it was a floor care product. Nothing there matched what was discussed. Any reccomendations on this topic? I normally paste wax but the front of my rig is hazey due to sun exposure. Any thoughts?
  • My RV is now 15 years old and I bought it used 9 years ago. For the first several years, I washed and then used various car/boat wax products. It seemed to be an endless and frequent process. In addition to accumulation of dirt, black streaks were an issue and seemed to start again very soon after washing and waxing.
    Three years ago I switched to Zep and have been extremely pleased with the results. The first application will require a lot of work. I washed with soaps and ammonia solutions to remove all traces of old waxes and finish. I then removed the oxidation by slowing rubbing with Bar Keepers Friend and a Scotch pad. After that application of the Zep finish was easy. I just use a small rag dampened in finish and lightly wipe it on. With a light application there should be no runs, drips or issues but it will take at least two light coats to achieve an attractive shine. I used 4 applications. The finish shed dirt and absolutely no streaks occurred for the first year. In fact I did not even have to wash the RV with soap. I just sprayed off the dirt. At the end of a year, it looked just as it did after Zep application. I did wipe on another thin coat. The next year I wiped on another thin coat. I will do the same this year after the Winter months. The Zep finish protects the finish from oxidation. I do understand that Zep does not include a UV protectant but that does not seem to be needed. If that is a concern, I understand the RV can be wiped down with Aerospace 303 and then Zep can be applied with no issues.
  • I saw this product Shine On but don’t have any first hand experience with it. I’m tired of the Meguiars deoxidizer (which works good) but doesn’t last despite using Meguiars polish and wax afterwards. The dullness just seems to reappear each year! I’m tempted to try Shine On. I’ve read a lot of poor reviews on the Zep floor wax and how it yellows.
  • applied the Zep Floor Polish on my white fiberglass rv in july of 2014 the front of my rv gets direct sunlight in the mornings and yellowed badly after 4 years the rest of my rv is fairly shaded by trees and still looks good.
    i am trying to get the zep off the front using the zep floor stripper so i can just wax the front a couple times a year but it has been hard to get it all off.
    mine sits at a seasonal site all year so the sun hits the front hard all year long so that's my experience with it.
  • This is the ZEP/Red Max Pro process. Use the cleaning procedure to remove the oxidation then, if you don't want to use floor wax, use the automotive or boat wax of your choice.
    The Bar Keepers Friend does an excellent job.
    Red Max Pro is no longer available, at least in my area. It was sold by Lowes.
    ZEP #3 is the same product.
    I use this process on my 96 Southwind, it does a nice job. No, it does not have UV protection. It does hold up well and it's easy to apply.
  • Zep will do nothing for your front cap issues. You need to get the oxodation off first. Best is to use something like the three step process McGuires markets for boats. Colonite also has a good line of products to clean and polish. My current favorite once you get the oxodation off is McGuires Advanced polomer.
    BTW Zep is one name, it used to be called RedMax Pro. Its still vinyl floor polish used in commercial applications. It has zero UV protection.
Looking for advice before your next adventure? Look no further.25,112 PostsLatest Activity: Feb 21, 2025
