OFDPOS's avatar
OFDPOS
Look twice before just pulling on through !
Hope this is the right place to put this ?!
Was setting at a red light today and across the street I see this guy pull up to the covered car wash place in his Class A get out walk to the side look up then get inside an proceed to pull on under the covered portion and took out his vent cover and looked like to be one of those new style T looking antenna's that are stationary !
You would think when he first hit the vent cover he would have stopped , NOPE kept right on another couple feet and there went the T looking antenna folding (braking) back !
I'm sure that's going to be a costly expense !!
Then two lights later I come up on another Class A MH in the slow lane turn his signal on and wanting to change lanes into the lane I along with 6 other cars are occupying . I was the 6th one back he's lined up in the middle of us, after about 200 ft he just starts coming on over everybody is locking it up cutting over into the center turn lane etc.
He just keeps going like nobody was there ,drove about 2 miles in that lane then switched back into the lane he was in in the first place and then turned off.
Some people you just watch and scratch your head thinking what were they thinking ??
  • Old-Biscuit wrote:
    And sometimes when you have your blinker ON with nobody letting you over you just have to take matters in hand. WHY MH wanted over......??? At least he used turn signal and let folks know his intentions. And it usually only takes a few seconds to let them in.
    You saw the turn signal......why didn't you just let him pull in front of you?
    Do you expect trees to be cut out of your way when you are trying to get into a site? If you can't get a lane change, drive around the block or take the next exit and try again with a bit better planning. Leave proper following distance between rigs and someone usually moves into the space.
  • Sometimes you don't hear/feel the first Oops!
  • Takes all kinds ... means some of us just have to try harder
