Community Alumni
Mar 24, 2016RinconVTR wrote:
The bars will not likely permanently bend because they are tempered as spring steel. They might break, but that would require more movement than your truck or trailer probably would allow before something bottoms.
Well they do bend, I've seen it for myself. Well distort is probably a better word. The overloaded bar gets an upward bow in it which makes it less effective at transferring weight and controlling sway. I could clearly see the bow when I put my bars next to the overloaded bars. It's probably not a permanent bow in the sense that you could probably knock the bow out by bending the bar in the opposite direction.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
