Acdii
Jul 02, 2018Explorer
LP issue? Maybe?
I noticed that if I am not using the gas as in the water heater or refer, but keep the tanks open, and go to switch the refer to gas, that it errors and I have to turn on a burner for a bit to get gas...
Old-Biscuit wrote:
When NOT using any propane for extended periods and Propane is valved for service then LP Reg goes into 'Lock-up' condition (normal)
What this means is W/O propane demand the reg can NOT hold 11" WC and pressure will rise...reg then goes into 'lockup' to prevent over-pressurization of system
Then you have to place a 'demand' on system.....lowers system pressure/reg then controls pressure & flow.
Can take a few minutes to fill ALL lines in propane system as each appliance attempts to light off.
OPD only stops flow of liquid into cylinder during filling processat 80% liquid level
OPD will NOT stop flow of vapor out of cylinder thru service valve
*Excess Flow Limiting Check Valve inside the ACME Green Nut CAN trip if service valves are opened too fast
