MarkieBob
Dec 20, 2013Explorer II
DougE wrote:
FYI. Dielectric grease is typically a thickened silicon lubricant. It is an insulator which is why it can be used on spark plug boots as a lubricant. When it is put in an electrical connection however, it will be sufficiently thin where the conductors touch that the insulation property is virtually negligible. There are contact cleaners like DeoxIT that remove corrosion, protect and lubricate electrical contacts without insulating properties.
So what are you recommending?
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 21, 2026
