DougE
Dec 21, 2013Explorer
Either will work on like new connectors. Which you use is up to you. Now you know that dielectric grease is actually an insulator, but at least it is readily available. If you don't like the mess of the grease or if you have a plug that has corrosion, DeoxIT would be the obvious choice.
Looking for advice before your next adventure? Look no further.25,180 PostsLatest Activity: Jan 21, 2026
