peaeye1
Jul 31, 2016Explorer
lug nut torque
I hope I am posting in the right place. I need the torque on a 8 lug,aluminum wheel.It originally had st23580r16 tires, but have been replaced with 85G16 Goodyear tires which take 110 Lbs pressure. I ...
peaeye1 wrote:SoCalDesertRider wrote:
The axle probably has 9/16" studs, so 120 ft-lbs should be the correct torque.
Axle's are 7000lb , I left that info out.
Yes, I have looked at the different charts, but wanted to see if I could determine torque without measuring the stud.
