peaeye1's avatar
peaeye1
lug nut torque
I hope I am posting in the right place. I need the torque on a 8 lug,aluminum wheel.It originally had st23580r16 tires, but have been replaced with 85G16 Goodyear tires which take 110 Lbs pressure. I have verified that the rim will accept the bigger tires. I have looked at charts online, but is there any way to determine the proper torque other than removing a nut and measuring the stud.
  • SoCalDesertRider wrote:
    The axle probably has 9/16" studs, so 120 ft-lbs should be the correct torque.
    Axle's are 7000lb , I left that info out.
    Yes, I have looked at the different charts, but wanted to see if I could determine torque without measuring the stud.
Looking for advice before your next adventure? Look no further.25,152 PostsLatest Activity: Aug 01, 2025
