DownTheAvenue
May 30, 2016Explorer
Grit dog wrote:DownTheAvenue wrote:
You need to slow down. Towing at 70 MPH can start to make most trailers unstable. Also, I think you will find most trailer tires can start to disintegrate at speeds above 65 MPH as they are not rated for anything faster.
Loll.
Funniest thing I read in a while!
You have experience with a trailer starting to disintegrate at 70?
It must have been a pretty nice trailer!
To the op. You most likely didn't have enough tongue weight as stated above.
For a trailer that size and the truck you go you don't even need a wd hitch. itll manhandle that trailer all day long.
Take the wd bars down or get some weight up front.
You need to sharpen your reading comprehension skills. I stated that most trailer TIRES can (not will) start to disintegrate at speeds above 65 MPH. You might consider reading this:
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=309
to better educate yourself.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
