cruz-in
Jun 02, 2016Explorer
Wow that is a great payload rating for a 2500HD truck...my F250 with a 9800 pound GVWR only has a cargo capacity of 2300 pounds....
Did you get the 3437 payload rating from the door sticker for yoour truck?
If your paylaod for your particular truck is 3437 yoou will be fine with that 5er.
I keep stressing "your particular truck" because the ford website lists a similar paylaod for my f250, however that is for a stripped down truck. Each item that is added above a stripped 2 door truck gas engine truck subtracts from the payload. Crew Cab, Deisel, 4WD, etc. all reduce that magical maximum payload capacity listed on the weebsite. Only way to know for sure is to check the door sticker on your truck.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
