WallynDiane's avatar
WallynDiane
Manual pump tank for winterization ?
We just ordered a Kropf Park model that will be delivered next spring. Our current fifth wheel uses a pump for pumping in antifreeze during winterization.
The Park model has no pump. Years ago, the now retired campground owner used a tank with a manual pump with a garden hose attachment that screwed into the rv to pump in he antifreeze.
I did a Google search and I didn't find that type of pump tank.
I want to research then purchase things we are going to need for our new Kropf this winter.
What are my options for using a stand alone pump/ something to get antifreeze into a Park Model?
  • SoundGuy wrote:
    Good grief, why adapt something when Camping World (and other RV retailers) sell exactly what you need. :S
    cause it's a lot easier to let a 12 volt pump do the work rather than hand pumping. somewhat depends on the amount of AF you are pumping also.
    bumpy
  • I have a cheap pump from Harbor Freight. I only pump a squirt into my City Water Connection and pump into my black tank flush. But, it should work for you. I made my own end that attaches to the hose connection on the unit from pieces at Home Depot.
  • You need a small liquid pump. You could probably adapt an RV water pump. Use clips to power it from your car battery. A sprayer on a hose would dilute the antifreeze as it pumped it in.
  • We Cant Wait wrote:
    What comes to mind first is some sort of bug sprayer where you put the antifreeze in the tank and then pump up the air pressure. This would need a water hose end adapted to the existing hose.
    Exactly what I am talking about. I can't find one with a water hose attachment. Just seeing what my options are. Thanks for the comment.
  • go to walmart, buy a small 1 volt boat bilge pump and appropriate fittings. pump away.
    bumpy
  • What comes to mind first is some sort of bug sprayer where you put the antifreeze in the tank and then pump up the air pressure. This would need a water hose end adapted to the existing hose.
