- FlashoExplorerI tow a Scion xB with manual trans. Prior to that I towed a Ford Escort with manual trans. Most vehicles with a manual trans can be towed four down.
- BumpyroadExplorer
fredandkathy wrote:
My 2007 Jeep Compass can be towed 4 down. The manual says no, but in correspondence with the factory, they told me that the manual is wrong.
I hope you got that in writing?
bumpy - fredandkathyExplorerMy 2007 Jeep Compass can be towed 4 down. The manual says no, but in correspondence with the factory, they told me that the manual is wrong.
- tatestExplorer II
rv-dreaming wrote:
I'm looking at a 2005 Chevy Colorado with a manual Trans. Owners manual is not real clear on RV towing.
Answer to original question is NO. Only specific manual transmissions.
Now you are getting down to specifics.
The manual transmissiom GM uses in the Colorado, GM does consider safe to flat tow. If a Colorado is flat towable, it will be because of the choice of transfer case in a 4x4, not because of the transmission. It has been a long time since GM has used any rear drive manual gearbox they want to let you tow, back to early '90s maybe.
Is the manual transmission offered in 4x4, or are those automatic only? - mowermechExplorer II
robsouth wrote:
No.
I agree. - tenbearExplorerThe only Subaru's that can be towed 4 down are the manual trans. They can only be towed 4 down, not on a dolly.
- paulcardozaExplorerIn general, many more manual trans vehicles can be towed than can auto trans vehicles. Odds are that most manual trans can be towed, but don't play the odds...... Investigate your particular vehicle!
- Francesca_KnowlExplorer
There's a service bulletin out on this subject that evidently covers the model/year of the truck you're looking at. At least according to The Bulletin, entitled "Guide to Dinghy towing", the only pre-2007 Colorado model that can be towed four down is the model with the "T150 transfer case". Do read that bulletin carefully as it looks like there are four/all wheel drive models that can NOT be towed four down, regardless of transmission type.
Info on light trucks begins on page three. - dicknellenExplorer IIIf it is 4WD yes manual & automatic,
2WD no manual & automatic.
If it is 2WD you would need to modify it with a drive shaft disconnect.
Regards, Dick - rv-dreamingExplorerI'm looking at a 2005 Chevy Colorado with a manual Trans. Owners manual is not real clear on RV towing.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
