MFL
Sep 21, 2018Nomad II
OP has to have a 3500, to get that much payload. The 2500 would just be wt of truck as it left factory minus the class 2 10,000 GVWR limit. The rear axle wt ratings should be similar between the 350/3500 models. The Ram may have a little higher GVWR on their 3500s? In any case, the OP made a good choice for a diesel truck, if it can handle the actual loaded pin wt, which will be much more than the 2500 lbs mentioned.
Jerry
Jerry
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
