Grit_dog
Sep 27, 2018Trailblazer
JIMNLIN wrote:
The trucks gvwr based yellow payload sticker is not used to determine a trucks legal/safe payload.
Higher in the bed payloads will come from the higher RAWR/tire load numbers
When using a truck makers weight specs for a certain package you will have to find the same package with the same weight specs on the lot for comparisons. Other wise your comparing apples vs oranges.
Don't bit into this yellow tire placard payload sticker thing for being the safe way to go. As has been said and shown many times before a gvwr based payload when used in the bed can and has overloaded some trucks RAWR. You sure don't want to overload a axle/tire/wheel or a rear spring pack.
Nothing wrong with the right logic.
Lol, if the door stickers aren’t conservative enough for you, you should sell your truck and stay home where it’s safe!!
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
