rhagfo
Nov 24, 2018Explorer III
Grit dog wrote:chiefcamper wrote:
Just traded in a 2015 Chevy 2500HD which was overloaded carrying our 40' 5th Wheel but it did not break, we only towed it a few times before buying the new truck. The new truck is a 2018 Ram 3500HD with a 6.4L Hemi. Yellow sticker payload of 4323lbs, 7000lb rear axle.
I am not sure claims of a 4000lb pin weight are always true with today's 5th wheels where the trailer wheels are now more forward. My unloaded mfg weights are 11575lbs (yellow sticker) with a max of 13,980lbs loaded. The unloaded pin weight is 1980lbs. So real world if I load the trailer with 2000lbs that would equal 13,575, 2000lbs seems like a lot to me but I am sure it is possible! Figuring a 25% pin weight would be @3400lbs. So an additional 900lb cushion for people, tools, hitch etc. seems plenty and I would still be under the axle and tire ratings. 25% seems high but for arguments sake I went high. YMMV :)
Any way you look at it far safer than the 2500HD which was a great truck!
Nice story. And your parting line is one that car salesmen LOVE to hear!
Now I'm gonna blow your mind. New Ram=nice truck. 2015 Chevy = nice truck.
What to YOU makes the Ram far safer than the Chevy you traded?
Your Chevy was/is identical to a 3500HD, save for stiffer rear springs.
Your Ram 3500 would be identical to a Ram 2500 except Ram changed the rear suspension 5 years ago to coils. Other wise same truck. For both brands, same frame, same power train, same brakes, Same tires and wheels, same axles. Actually the rear axle in your new ram is the same as the one in your Chevy.
Point being, the new truck is not inherently safer AT ALL than your old one with one exception. The rear suspension is stiffer, which can be accomplished for $200-500 with any number of easy, proven, bolt on suspension products.
Again, nice truck, but it's only "safer" in your mind....which is the most important part I suppose since you're the one driving it.
X2
until you step up to a DRW, there is no real difference between 2500/250 and 3500/350 SRW.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
