kwinterb's avatar
kwinterb
MaxBrake Controller issue?
When I first had the MaxBrake Controller installed I never noticed any “excess noise” coming from my hydraulic brake setup in the 5vr. Then one day, I got out and heard what sounded like the hydraulic brake pump running on the 5vr. My brake lights were not on but I pulled the cable and the noise stopped. This went on for a few trips happening intermittently. The trailer brakes seem to work fine and I’ve checked the hydraulic fluid reservoir in the 5vr and it is full. Now it seems to be happening always and I’ve found I can stop the pump from running by turning the adjusting knob down to zero, but of course that causes a problem when I am towing.
So the current issue - When I am parked, brakes off and gain on zero, everything is fine, as soon as I barely start to turn the gain up, it engages what I am assuming is my hydraulic brake pump on the 5vr. When I turn it up, neither my truck or 5vr brake lights turn on, but when I engage the truck brake pedal, the lights work fine. Turing up the gain will also increase the intensity (noise) coming from the hydraulic brake pump. When I drive, I leave the gain just high enough to have the brakes work ok and when I stop after a while, the trailer brakes are not excessively hot as if I had been riding with the brakes engaged. So, where’s my problem?
Ken
  • My magnets were buzzing while parked, so I recalibrated the sensor and all is well now.
    I think you are on the right track.
  • Well, after re-reading the "manual" I decided to try and do the calibration step again. That seemed to do the trick. :)
  • kwinterb wrote:
    Thanks for all the info/tips everyone. Wow didn't realize a 5 year warranty was in place. I'll call them.
    Let us know what the problem was.
  • Thanks for all the info/tips everyone. Wow didn't realize a 5 year warranty was in place. I'll call them.
  • I think you should be calling MaxBrake customer support. They do have a 5 year warranty.
  • benk wrote:
    Sensor in that it is not returning to ZERO PSI, but telling the controller
    that there is some PSI. That can also be a bubble in that TV brake
    line. It compresses during braking and when the brake pedal is released,
    it will expand to keep a bit of PSI in 'that' brake line.
    Forgot to mention that there is another issue, IMHO, with MC PSI sensed
    That is with MC's that have more than one brake line
    As any of the MC PSI sensed only sense
    ONE
    line
    The reason today's MC's have more than one line is a fail safe design
    If one line should be damaged, the other line 'might be' or 'should be'
    still operational. Albeit only two wheel braking....never the less
    braking of lesser degree
    If the line that goes south is the one a trailer brake sensor is
    on...no trailer brakes...
    Could have been there all the time and 'just' noticed it
    This tosses a monkey wrench into what I was thinking and will touch on
    that below
    Ken
    First, I do NOT know much about hydraulic trailer brakes (other than
    surge brakes), but have designed industrial braking systems. From
    drum/shoe. Shoe moves inwards onto a drum that weighs in the hundreds
    of pounds. Disc brakes were in the 48" dia range. Consulted with an
    after market 'big' brake firm in S Calif and E Coast, both cars and
    SUV applications
    Assumption is that the trailer brake system has an accumulator for
    quick response. That then has a pump run till a preset PSI is reached
    (that has some margin for bleed off so that the pump will NOT run all
    the time)
    That variable 'dump' valve must be proportional and the brake controller voltage
    is the control for that variable rate of flow/PSI
    There is another potential design and is that the calipers are normally
    'closed'. Meaning if power is lost, they close to squeeze the disc
    and the hydraulic pressure is to 'open' them, or release the disc
    That would then have the below valve normally 'open' and close when
    power is applied
    Again, my knowledge at this time for hydraulic trailer brakes is
    limited. So I could be all wet in the above
    MaxBrake, and assume MC PSI sensed with a gain adjustment. Since MC
    PSI sensed, that gain only comes on when PSI is sensed, or does it
    also sense the brake pedal switch? If so, then a MaxBrake can lead
    the MC PSI just like my P3 can
    Initially thought it was always there and you just 'noticed' it, but
    that monkey wrench throws that off or out
    Since the trailer hydraulic pump stops when you turn the gain down
    to zero, it indicates a problem in the MaxBrake controller and/or
    the sensor
    That is one of my comments of their instructions that lack completeness
    or fastidiousness in design...not instructing to bleed that whole
    line, but just the new 'T' and stub line
    Or the controller is out of adjustment and/or is going south. Could
    be the gain circuit or the potentiometer
    Please post back when you find the root cause. Either back at the
    trailer brake system or the MaxBrake control system
  • I have no experience with hydraulic trailer brakes other than surge brakes on a boat trailer.
    You might try unplugging the sensor in the brake line and see if it still runs. If it does there is either pressure on the brake line when there shouldn't be or a bad switch.
    Just a thought.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
