monkey44's avatar
monkey44
Nomad II
Sep 13, 2014
Memory Foam pads?
We need a new mattress in our Truck Camper - and of course, headroom is an issue in the cab-over.
We now have a standard mattress in it, about 7"/8" thick, and would like to try what's called a 'memory foam' (4" thick) topper. Any reason it can't sit on the cab-over floor directly -- will probably put a half inch of solid insulation under it and lay it on that.
Any comments on this method or mattress type -- it seems a great answer for the shorter head-room area too.
The 'memory foam' part does not really 'remember and form' itself, right? It returns to the flat/level foam when you move or get off it? Is that accurate? Thanks BD
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
