buffalofrenchy
Feb 13, 2018Explorer
How to clean it is the question as I do not have access other than through the vents... To clean this disaster I would have to cut and remove the galvanized sheet metal pan, rework the insulation from the bottom and then find a way to re-enclose the underbelly. I don't know what to do: whether I do the above or just making sure that I seal everything: sealing the underbelly from the outside environment and from the inside RV. I am leaning toward the first option but I don't know how realistic it will be, some section is very cluttered with 3 axles and outdoor plumbing attachments and little clearance to the ground.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
