tenbear
Feb 13, 2018Explorer
I didn't have much space between the two sides of the floor so I just filled the hole with foam. I might try to vacuum the space then seal the top and bottom. The droppings will eventually dry up. As long as you don't get a smell in the MH you should be ok. If there are no moving parts you could just fill the space with foam.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
