wa8yxm
Jan 13, 2014Explorer III
Does not work on 12 volt:
Did they leave the house batteries in?
Are they any good (use volt meter).
Are they disconnected or turned off at a switch
What converter do you have (Only matters in a very few cases, Converter may be part of the power distribution panel for the house, epically of both fuses and breakers are in the same panel).
Bad wire
Other problem.
Give us the make and model of the converter.
The one thing it is NOT is the transfer switch... UNLESS you have one of a very limited number of converters.
Bad wire
Other problem.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
