Bedlam
May 19, 2015Moderator
By running LED trailer and motorcycle lights, you should be able to use existing signal wiring. As was posted, use dedicated turn signals on the trailer so you do not need to run a converter. Your turn signal circuit will need a new LED compatible flasher or load resistors for the signals to work properly.
