jwc99's avatar
jwc99
My scale weights
Took my rig to the scale, here are the numbers.
Truck specs
7600 GVWR
3950 GAWR FRT
4300 GAWR RR
10900 towing capacity
16700 gross combined
All weighs were done with a full tank, me in the truck, and everything loaded for a normal trip. We were on our way home from a trip when I stopped to weigh.
Weights from scale
1st weigh hitch connected
Steer axle. 3340
Drive axle. 3940
Trailer axle. 7420
Gross weight. 14700
2nd weigh trailer connected bars unhooked
Steer axle 3080
Drive axle 4320
Trailer axle. 7300
Gross weight 14700
3rd weigh truck only
Steer axle 3560
Drive axle. 2680
Gross weight. 6240
I'm getting a little truck squirm, not sway. I think the biggest problem is the P rated tires. If the weights look OK will going to LT tires help with the squirm?
  • Well. you are losing 220lb off the steer axle. You are getting about 1/2 of your lost weight back. "Some" manufactures say that is good. If you are good with that. Higher weight tires will help.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
