bobby7718's avatar
bobby7718
Need help - Weight distribution hitch installation pics
Hi,
I have bought a Jayco travel trailer together with a Camco Recurve R3 Weight Distribution Hitch recently.
The ride has been bouncing and swaying. Second visit to the dealership this afternoon, the technician adjusted the hitch a bit, seems getting a little better, but still bouncing and swaying on the way back to home.
Here is the detailed info of the TT and TV.
- TT: Jayco 267BHS, 30 feet, dry weight 5975.
- TV: 2017 Ford F150 with towing package (checked with dealership via VIN, was told max payload is 3000 lbs, and max towing capacity is 14,000 lbs).
Please also see the attachments for the pictures I took after today's adjustments.
- the altitude of TT and TV
- how does the setup looks like
- measurements before and after W/D
I know I need to expect some swaying if there is big sized truck driving by, not sure how much to expect. The ride I feel uncomfortable and unsafe. Need some help before either upgrade the TV.
Can someone please help to take a look at the pictures to see if anything significantly out-of-line could explain the bouncing/swaying.
In addition to the camper dealerships, where are the places to get the WDH professionally installed ?
Thank you in advance.
  • Looks to me like you are nose down on the trailer. Try flip your stinger and adjust to level your trailer. Also looks like you are in the outer hole on the stinger, possibly because your spare is in the way? Longer the fulcrum the more bob.
    Also how many miles on the truck? Original shocks could be worn?
  • thanks you all for chiming in. Brand new user of this forum. I updated this thread a few times with the pics, hopefully this time the pics should show properly. Attach the pics here in case the original one are still not refreshed.
    Prior to the second visit to the dealership for the last adjustment, I have read through the sticky threads of WD hitch(which was super helpful)and was able to adjust the hitch a bit, but still bouncing on the way to the store.
    My next attempt will be : try to adjust the tilt-head downwards a bit to produce slight more tension on the bar, hopefully will bring down the front fender(H2) a bit towards H1.
    In the mean time, I also realized that the tire(or the tire pressure) might contribute to this after read ***Link Removed***.
    I checked my tires and the pressure, which is what I have right now.
    - 275/65R18 116T , Max Load 2756 lbs, Max Press 50 PSI.
    I also noticed that my current 4 tire pressure are all 40 PSI, yes, I didn't max out the tire pressure before the towing. I will max the rare to 50 PSI, the front 48 PSI as the next try.
    Will report back. Yes, will plan a visit to CAT scale get the weights.
  • There's a sticky on this forum that may help you:
    wdh setup
    Good Luck
    I think Lynnmor's instructions will do it.
  • To get the proper weight transfer, your owners manual says this on page 281:
    Weight-distributing Hitches
    WARNING
    Do not adjust the spring bars so that
    your vehicle's rear bumper is higher
    than before attaching the trailer.
    Doing so will defeat the function of the
    weight-distributing hitch, which may cause
    unpredictable handling, and could result
    in serious personal injury.
    When hooking-up a trailer using a
    weight-distributing hitch, always use the
    following procedure:
    1. Park the loaded vehicle, without the
    trailer, on a level surface.
    2. Measure the height to the top of your
    vehicle's front wheel opening on the
    fender. This is H1.
    3. Attach the loaded trailer to your vehicle
    without the weight-distributing bars
    connected.
    4. Measure the height to the top of your
    fender a second time. This is H2.
    5. Install and adjust the tension in the
    weight-distributing bars so that the
    height of your vehicle's front wheel
    opening on the fender is approximately
    a quarter the way down from H2,
    toward H1.
    6. Check that the trailer is level or slightly
    nose down toward your vehicle. If not,
    adjust the ball height accordingly and
    repeat Steps 2-6.
    Once the trailer is level or slightly nose
    down toward the vehicle:
    •Lock the bar tension adjuster in place.
    •Check that the trailer tongue securely
    attaches and locks onto the hitch.
    •Install safety chains, lighting, and trailer
    brake controls as required by law or the
    trailer manufacturer.
  • If you should decided to ditch the hitch as a last resort then I have had very good experience with the Equalizer WD hitch. It is easy to use and set up with no chains to contend with.
  • I can't see the pics either, using Chrome. I checked out that hitch and it's a new design for sure! I think I saw a rig using it and thought, wow.. The hitch bars are upside down!
    Anyway, you don't have to check with the dealer on what your trucks payload is... It should be listed on one of the stickers on your drivers side door jamb.. #3000 payload for an F150 is one of the "unicorn" HD Payload F150's that only seem to exist in brochures..
    Anyway, sounds like you don't have enough tongue weight off the cuff without knowing anything else..
    I can't see the pics, so just shooting from the hip on it..
    Good luck! Mitch
  • Your pictures area not showing up. Please upload your pictures to this site and then copy/paste the resulting URL into your post without making any changes to it -no additions and no subtractions.. This will then show your pictures and they will be properly sized for use in our forums.
    Barney
  • I don't know anything about that particular hitch, but based on your description and the measurements you posted, I think you need more tension on the spring bars.
    The fact that your front fender measurement with the W/D hooked up is still higher than with no trailer means you're not transferring enough up to the steer tires.
    Back when I had a TT, I adjusted it so my front measurement was the same if not a slight bit lower than when un-hooked.
    This is good for ball-parking it, but as others will probably add shortly, you should get to a scale to see what is really happening.
    If this system is anything like mine was, the more spring force there was, the more sway control it provided.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
