jbluetooth's avatar
jbluetooth
need help choosing the best solution to solve sway issue
Hello everyone. I'm a motorcycle racer who's been towing bikes to the track for a long time, but I consider myself a beginner when it comes to towing a big trailer. I upgraded from a small box trailer to a 22ft toy hauler a year ago and it came with a WD hitch and sway bar. The WD hitch is an old Reese system with 750lb trunnion bars that slide on friction pads, and there's also a small friction sway bar that attaches on the small ball on the side of the hitch. I have a 2014 Tundra with the smaller 4.7 V8. The trailer is long for a bumper tow and has a lot of weight on the hitch, plus occasionally I have another bike in the back of my truck (though most of that weight is in front of the axle). I've been towing this for awhile now learning and doing what I can. At first, the handling was terrible. I played around with weight loading in the trailer a bit, and finally added airbags to the truck, then readjusted the weight distribution hitch to level out the truck and add some weight to the front wheels. This helped a lot, but at this time, I noticed that the spring bars were only 750 lb rated. I weight the truck and trailer loaded and I would guess that on average I have 1200-1500 lbs on the hitch, plus sometimes a bike in the back of the truck, but sometimes the hitch weight is probably higher than 1500 if I can't dump the Grey tank and it's full. My hitch weight could be as high as 2000 lbs.
After adding the airbags and readjusting, the truck pulls much better and straighter, but still sways really bad if I pass a semi, even at 55-65 mph. I want to fix this, hopefully without getting a new truck. I'm assuming the really undersized spring bars are hurting the effectiveness of this system, especially with a Tundra which is pretty light in the front compared to a big diesel. However, I'm not sure how big of spring bars I can get for this setup, I'm working on that. I've found 1200 lb, and maybe 1500 lb. So I guess my question is do you think 1200-1500 lb spring bars with this setup will correct the issue? Or should I look at a different distribution system that goes higher in weight, like the Reese Dual Cam 1700, or even something else? It doesn't seem like there are a lot of systems designed to handle this kind of tongue weight.
Or is there something else entirely that I'm missing?
Any input is appreciated. Thank you for your time!
Jesse
  • With that much tongue weight you are exceeding the receiver rating of the Tundra by a significant margin. You are also likely over the payload rating before even adding another bike in the bed. I wouldn't be surprised if you were exceeding the axle and tire ratings too. 1500-2k tongue weight is well into HD truck territory. Unfortunately any suggestions will just be Band-Aid fixes to a "not enough truck" situation.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
