navajochief's avatar
navajochief
Need Help With Determining Weight Numbers
Truck and Trailer together: 21,540 lbs
Truck only: With Hitch attached: 8,060 lbs (GVWR) 11,400 lbs
Trailer at rear axles: 10,240 lbs
Front GAWR: 5,700 lbs
Rear GAWR: 7,000 lbs
I wasn't able to get the vendor to weigh my axles individually and/or my hitch weight as well.
So this is what I got on my own:
Hitch wt: 3,240 lbs
Total wt of trailer: 13,480 lbs
Is my math right?
I weighed myself at a public truck scale in town that told me they weren't able to help me with weighing my hitch weight and axle weights individually. I plan to go to our local CAT scale the next time for comparison. However, with the numbers I was able to get this is what I got for my hitch weight and total trailer weight.
Thank you.
Mark
  • Looks right to me.
    Total combined weight: 21,540
    Trailer axles: 10,240
    Truck: 8,060
    Subtract unhitched truck, and trailer weight from the total weight leaves 3240 lbs. which is the weight that sits on the truck with the 5th wheel attached, i.e. hitch/pin weight.
    FWIW that works out to 24 percent hitch weight, might be a bit high but don't know if this is a toyhauler or a standard 5th wheel or what.
  • Fill in your signature.
    Bottom line what does your rear axle on the TV weigh hitched and fully loaded?
