chakatania's avatar
chakatania
Need recommendations: Drinking/RV/Boating Hose
Our white "Camco" 22803 TastePURE Drinking Water Hose drinking hose just burst today after 14 months of use (Amazon purchase).
Added side note:
[COLOR=]>>> We DO use a water regulator at campsites.
The hose burst when using it to wash the RV at home. In fact this hose never leaves our home. It's for filling up the RV from our house when prepping for a trip.
Can anyone recommend one that is of good quality and that will last? Or do these hoses only have a 1 year "usage life"?
Also the "safety" of drinking hoses seem to be a continuous debate.
What do YOU recommend or what has worked for YOU?
  • Drive over to Thousand Oaks to Coast RV and pick up what you need/want. Nice store, nice folks. I have a flat white hose that the OP bought in 1990. Coils about 1" thick and 12" diameter. I replaced the ends with Gilmore repair ends and other than scratches on the surface of the hose it's fine.
    Unless we are staying put for three or more days, I use the water from the tank. I agree about the regulator going on the spigot and then the hose. Only problem I know of is you might forget the regulator and then it gets sold for $2.00 as used in the store.
    During the last year or so I've seen a lot of "Y"s and regulator in campground stores. Never seen an adjustable regulator with a gauge in the store. Maybe for >$50 folks remember those.
  • White impart less taste of rubber to the water. White is also the standard color for drinking water, other colors may be used for other purposes.
    There is no law or rule, so you are free to use what you want.
  • Teknor Apex NeverKink hoses are guaranteed for life. I just mine replaced because it had a couple of kinks in it. Customer service was great.
  • The hoses from the RV Water Filter Store are about the best I have encountered. They are not inexpensive but are very high quality and are very easy to coil. You have your choice of brass or stainless steel fittings. Their pressure regulators are also the best you can find.
  • Buy another white hose, or the color of your choice, and also buy a pressure regulator.
    Put the regulator on the CG spigot to protect your hose and RV water system.
  • Tvov's avatar
    Tvov
    Explorer II
    I just bought the white hose with blue stripe from Walmart marked for drinking water. Works fine, except the connections at the ends aren't great - takes some fiddling to get them to be leak free.
    Some people say it is a myth, but I have found that hoses marked "drinking water" (which are usually white with a blue stripe) definitely impart much less of the rubber flavor to water.
  • I know there are different quality hoses, seems the stiffer ones are better, but then there is that coiling factor. Not to sound paranoid, but I dont drink campground water anyways.......just dont like the taste of some. Bottled water is cheap around here
  • "What do YOU recommend or what has worked for YOU? "
    A hose is a hose is a hose!
    I'm 78 and still alive.
    I grew up drinking out of a green garden hose, and since RV'ng I have used every color there is.
    My criteria is get the lightest weight one, and one that will coil easily and I could care less about the color
    Jack L
