dmzno98 wrote:
My wife and I 62, lost everything in Katrina and now Harvey took the rest. We can't go through this anymore. Life is too short and it keeps kicking our butts. We have access to a F150 and would like to cash out (may need to live in it for awhile) and get a truck camper or a 18ft appox travel trailer. What truck camper is best for f150? is there any negatives about a truck camper we should know? were in good shape, what about dogs? price is a major consideration and negatives about traveling, parks etc. Any help would be appreciated
Sorry to hear about your troubles. I can certainly appreciate your feelings at this time.
I think that pconroy238 gave some good advice. I would recommend you defer any decision until you are able to give a good amount of thought to your position and where you want to go.
That said however, I have been RVing for many years with both trailers, fifth wheels, Truck campers and now a Class A, so I can offer the following advice:
A Truck Camper is probably not what you want to use.
- A F150 just does not have the capability of carrying a camper that has enough room to live in comfortably long term
- Many campgrounds will not allow you to take it off the truck so you are forced to move your home every time you need to use the truck
- The weight of a camper will put a lot of stress on your F150 resulting in more frequent repairs and a shorter lifespan
If you want to understand how adding a camper will affect your truck weights, try this calculator:
http://www.visualsc.com/tc_calc.htmIf I was you, I would look for a good used trailer. Although the towing capacity of the F150 is a concern, there is more "wriggle" room.
- If you are not planning on doing a lot of travelling, you can push the combined weight rating (GCWVR) a little. Just don't exceed the rear axle and tire ratings
- Using a good weight distribution hitch will help a lot to improve the safety and capability of the truck
- Make sure the trailer tires and axles are in good condition. Keep the bearings well greased and service regularly
- There are lots of floor pans out there that will be adaptable for full timing
- Make sure you get at least a 25 foot trailer as some parks have a minimum size limit (some also have a age/condition limit)
- Look for a trailer with an "Arctic" pack so that you have the option of using it in cold weather.
Good luck getting back on your feet. Hopefully, things will look a little brighter when everything settles down in a few months.
