- Y-GuyModeratorThis thread was moved here, but the OP posted in this forum and already received answers. I'm going to close this thread and link to the other thread to continue any discussions in.
Want to use a tow bar to pull a titan xd - pauldubExplorerIf it's 2WD, you could tow it if you could get a driveline disconnect for it.
- carringbExplorerLooks like the Titan XD is only approved to be trailered. Flat and dolly towing are not supported.
- John_WayneExplorer II1st is it flat towable ? If not you will need a driveshaft disconnect. Then all of the following. Baseplate. Tow Bar,Braking system on Titan, brake light wiring. Hitch on Motor Home rated high enough for the weight of the Titan.
- 2oldmanExplorer IIeveryone here needs help and anwsers.
- RoyBExplorer IITo get to the dinghy forum section here just look in the OPEN ROADS FORUMS at the beginning of the lists, scroll down the listed forums a page or two and you will see the DINGHY FORUM listed there...
Most everyone however on here use the NEWEST button which will refresh all the the RV NET Forums and list the newest entries... I see a new DINGHY FORUM entry just a few few post down the list here...
Hope this helps...
Here of late every time I do seach I get the standard CAN NOT FIND routine - Please try again... Like maybe the RV NET is overlaoded or something hehe...
Roy Ken - brysont3405Explorerhow do I go there
- Dennis_M_MExplorerYou will get better results if you put your post in the Dinghy Towing forum and state what you need in the subject line instead of just "need help"
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
