innermusic's avatar
innermusic
Nervous Nelly Newbie
Bought my first TT and brought it home today. I noticed that when I look at the truck hooked up to the TT from the side, the TT angles downward toward the hitch somewhat. Is this normal, or is the whole thing supposed to be relatively level?
It's a class IV hitch that was factory installed when I got my f-150. The tongue is a 2 1/2" drop.
Thanks!
  • Welcome to the Portal!!!
    So much depends...and you have lots to read up on. This portal (rv.net,
    woodalls.com, etc) is a good one...but learn to listen to the advice
    that sounds good to you AND decide if you believe in the specializations,
    ratings system, etc
    If not, then do whatever you wish, but know that doing that will
    relieve the OEMs from the hook (warranty and liability)
    If yes, then read and learn HOW2 on sizing to your TV's ratings, the
    brake controller, and tons of ETC...a bit academic since you have
    already purchased the setup, but important for you to proceed. Suggest
    still gathering the specifications for both your TV and Trailer and
    going out to actually weigh the whole setup (fully loaded and empty)
    Depends...because the WD spring bars (if you have them) and the amount
    of weight transferred (WD'd...weight distributed) needs to be in the
    correct 'range'
    The orientation of the trailers tongue should be level at it's highest
    pointing, to slightly down...when the WD adjustments are in the correct
    range
    Yours is a very, very common question and here is a good stating
    point for you:
    New member with some confusion
    BenK wrote:
    Welcome to the portal !
    First note that I do NOT say no you can't, nor sure you can...because
    there is only one person responsible for the setup...the driver and
    that might not be the OP, but their partner or whomever is driving
    So provide the metrics on HOW2...
    There are many oblique thoughts and beliefs on the ratings system. From
    what is 'dry' to what is 'curb' to what is the actual 'payload/cargo', etc
    Second, decide if you believe in the ratings system or not
    If not, then do whatever, but know that you have taken the OEM off both
    the warranty and liability hook
    If yes, then read up and learn HOW2 figure it out
    Simple math, but requires actual weights and why some have suggested
    going out and actually weighing your setup (TV & trailer) axle by axle
    Here is how the ratings system looks like in graphical form and another
    note: folks take one of those ratings out of context. Either without
    regard to the interdependence's of other ratings as either prerequisites
    or as an absolute
    It is 'system' and everything plays together in a give and take way
    Meaning that if you wish to take the MTWR (max tow weight rating)...then
    you have to give up loading up the TV to it's GVWR and reduce the
    TV's weight
    howmuchcanitow howmuchshoulditow
  • These folks will need a lot more info, but I'll ask the first question.
    How much does your hitch sag with the trailer on it?
Looking for advice before your next adventure? Look no further.25,167 PostsLatest Activity: Oct 04, 2025
