fpresto
Jul 08, 2014Explorer
Take a car or truck, park it beside your trailer and using a good set of jumper cables jump straight to the slide motor. That will eliminate the trailer battery and wiring from the equation. A good battery jumper pack should also work well. If it works with the jumper check your ground connections. A loose or corroded ground can cause your issue.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
