bigtime_077
Mar 17, 2014Explorer
New camper frozen water lines
I just bought a brand new 2013 Dutchmen travel trailer. Stupid me I opted out of paying the dealer to winterize it again in case of cold weather because I had RV antifreeze at home and wanted to do it myself. Well one thing led to another and I didn't get it all done as I got called away from it and last night it got down to 9 degrees here.
I got to the water heater and got antifreeze out of the kitchen sink on both sides before I ran out of antifreeze so I know those and the pump is all good. I got some antifreeze this morning and got home from work tonight and quickly pressured the system back up to try again. I can get a very slow trickle of antifreeze out of the toilet and the cold water side of the sink. Nothing out of the hot water side, either side of the tub, nothing out of the outside water port or the high pressure water hook up. It must all be froze.
Low of 6 tonight and high of 23 tomorrow and high of 42 on Tuesday. How screwed am I? Are the water lines under the trailer fairly durable or will they likely rupture? Bottom of the trailer is all covered so I can't look unless I pull that covering off.
My plan is to wait until Tuesday and Wednesday while I am off and it is warm to try again. Once I get antifreeze flow my plan is to shut all the faucets and everything off other than the pump and see if the system will stay pressurized and look for antifreeze coming out of the bottom covering to know if I have a leak now.
Any words of advice and how screwed am I?
