FULL-THROTTLE's avatar
Mar 22, 2020
New Camper problems
I need some help with my new 2020 Cougar 26RBS, When it was plugged into the rv stores 240v plug everything worked perfectly, I drive it home and nothing works, I plugged a 120v from and outside of my house outlet to the 25ft cable, now I get lights and tv and refrigerator. I pulled the brand new battery and put it on my charger and it was completely dead. So I connect jumper cables from my truck to the battery cable on the rv and everything works, slide, fridge, awning so assume I have let the battery charge overnight. I put it back in the rv and again nothing, I put the jumper cables to the rv battery and everything comes alive I don't get it I assumed with 120v from the house it would run the slide and awning. What am I missing here?
Thank you,
Fran
  • Battery disconnect switch.
    Reverse polarity fuses blown from battery being connected backwards.
  • If it was 240 volts, everything is fried. No RV dealership would do that. Have your battery checked. Then I suspect the converter. The slide and the awning run on 12 volt.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
