carpetguy2's avatar
carpetguy2
New Ram and chucking in the 5ver
My Father recently purchased a 2017 Ram cc. Lb. 2500 6.4 Hein
And a new 5ver denali 316 .
This new puck system people say they have no chucking but I drove it and it chucks quite a bit.
Any info on what he can do .
Thanks
  • carpetguy2 wrote:
    He his still trying to figure out his truck as Well
    I will tell him on the air bags.
    Is there a switch .I only drove it once.
    Thanks
    Once the load is applied push the Alt Trailer button. Leave it alone and it will ride more level and make entry and exit easier. Right before lowering the landing gear go into settings then scroll to suspension and hit tire jack mode. This will keep the truck from trying to adjust it's height when lowering landing gear. Once RV is removed the trucks system will go back to norma. NO BUTTON TO PUSH.
  • ependydad wrote:
    Durb wrote:
    Don't get caught up with truck modifications such as shocks or air bags. Chucking forces are caused by the trailer and will be transmitted to your seat before they even reach the truck suspension pathway.
    I can agree/attest to this. I swapped out shocks on my truck trying to fix the problem. It hasn't made any difference.
    He has factory rear sir ride, no aftermarket shocks available. No need as they are quality US Made Nitrogen shocks.
  • We bought a 2017 316RES back in may and I've not had the first rattle or chuck out of my hitch. I have a Lil Rocker that I've used for years. Your hitch weight is 2030 empty.
  • IBcarguy wrote:
    Durb wrote:
    Chucking is caused by the trailer, not the hitch. Various factors such as length, suspension design, and weight distribution will either minimize or maximize chucking. Don't give credit to a hitch mounted via a puck system if it is hooked up to a trailer with a tendency not to chuck. If your trailer has a tendency to chuck any solid joint hitch wether it be B&W, Andersen, Curt or Reese no matter how it is mounted will transfer the chucking energy directly to your truck.
    Your choices to mitigate chucking are two fold. One, you can reduce chucking generated by the trailer via trailer suspension shocks or weight redistribution. Changing the length is not practical. Two, you can dissipate chucking energy at the hitch via air ride hitches or pin boxes or other devices such as MORryde and Demco pin boxes. All these methods will help keep chucking energy from your seat back. Some are better than others.
    Durb, this is a great description of the cause of chucking. Most of the 'remedies' out there just don't seem to make a much difference. I know, I tried many of them short of modifying the trailer suspension. The shock absorbing pinboxes do not cure the chucking, it simply dampens it enough to make it acceptable. This is a common problem with FWs. Just look at how many aftermarket companies are making shock absorbing pinboxes and how many are sold. It's a good solution to a design problem that the manufacturers won't address. Jayco (and others) even offer the MORryde box as a factory option.
    That's one reason over the road trucks have air ride seats and they take a wild ride on some roads too.
  • I also put water in the fresh tank.Makes all the difference in ride. With it empty or less than half full,yeh ha,rodeo is on.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
