Kodi's avatar
Kodi
New Toilet recommendations
We need to replace the toilet in our RV. The one we have is terrible. It’s a Thetford Style II. If the spring for the flusher falls off you have to replace the base. Does anyone have another toilet they can recommend?
We are traveling in a 5th wheel 2015 jayco eagle sl ht 26.5bhs
  • We have the Thetford Residence. One could search this Forum for `toilet' and read on.
  • Cummins12V98 wrote:
    Dometic 320 with sprayer, elongated bowl in standard height, that is actually handicap height.
    Using ours for 4 years full time! Replaced one vacuum breaker recently.
    QUALITY unit!!!
    I agree! If you get this toilet, make sure you get the sprayer too. I opted to get the toilet without the sprayer and regret it now.
  • The Bravura also fits most bolt patterns, where the Sealand may need flange to be replaced or modified.
  • enblethen wrote:
    I would suggest the Thetford Bravura
    Bravura
    X2 These are great,one thing about these that set them apart is the Easy-off seat and cover Pod for easy cleaning or service,if your Toilet Water Module fails you don't have to remove the whole toilet,as you have to do with most others,to replace it.
    Just pop off the seat cover and there it is,easy to replace.
  • Dometic 320 with sprayer, elongated bowl in standard height, that is actually handicap height.
    QUALITY unit!!!
