joelc's avatar
joelc
Nomad
Dec 08, 2016
Toilet Woes - New Recommended
I have a Thetford model 42049. It is a porcelain toilet at least on top. The bottom piece is all plastic. Recently the "ball seal" started leaking. I noticed the seal was dry and the "ball" scored. So, I ordered a new kit. When I got the kit I did notice the directions were written very poorly. Anyway, I took the toilet apart and installed the seal. In order to get to the seal one must remove the foot pedal. There is a very tight spring there, and all went well until I tried to get the coil spring back on. As much as I tried I could not. I ended up messing up the inside chambers on the inside of the plastic pedal. I reinstalled the toilet and it works minus the spring. We have to raise the pedal manually. I have had it with this toilet, and am not about to order another pedal which I will surely mess up too.
My question! What is a good replacement toilet that will last and is easy to service. This one is 2012.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,416 PostsLatest Activity: Aug 31, 2026
