Pat_in_Speedway's avatar
Feb 01, 2015
New Trailer - Now time for a WDH
Yesterday we signed the papers for a '15 Shasta Oasis 25BH. Some of my particulars:
Trailer: 530lbs dry hitch weight, 4300lbs UVW
TV: 2003 Toyota Sequoia w/a 6200 tow capacity
I told the dealer I'd supply the WDH and they'd install it when the trailer is shipped in a couple of months. Having trailers that have been 1600 and 2500lbs, I've never had need for a WDH until now. I don't have the $$ for a Hensley, so I'm basically looking for thoughts on what's a good fit based on my combination. One thing I want to make sure I get one where it's not necessary to remove the sway control to back up! Other than that, I'm open to suggestions. Many thanks!
  • campigloo wrote:
    I'm still old school. The EazLift still works good for me. I pull a 36' TT with a Ram 2500. I use two sway bars, one should be plenty for you, and have never had a problem with it. I have never bothered removing them for backing. If you are easily embarrassed they may not be for you. When making tight turns they will groan a bit,, but so far I have no reports of anyone being hurt by it. It is probably the cheapest system out there plus I can adjust the action to fit the road conditions. If the road is slippery I can release them with the turn of a handle. If I am making several tight turns, like in some campgrounds, I can release all resistance. If it is extra windy I can tighten more. I tow 10,000 plus miles a year.
    x2...preferred my dual friction bars and my standard weight distribution hitch to dual cam.
    I didn't remove them to back up either.
    Thanks,
    Jeremiah
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Equal-i-zer user here, works great. Have also had the EZ Lift with single friction control, and that was OK.
Looking for advice before your next adventure? Look no further.25,101 PostsLatest Activity: Jan 14, 2025
