rctoyguy's avatar
rctoyguy
New Truck = Bigger Receiver = Unexpected Problem
this past weekend I traded my '15 Ram 1500 for a '13 Ram 2500. I have now discovered that this 2500 has a much larger receiver than my 1500 did. (it's also larger than my brother's '12 Ram 2500) - I think I have found that this truck's hitch is a Class V... All great,
EXCEPT...
My WDH for my travel trailer is now too small for my truck:
I know that I can get an "adapter" that is basically a square tube that fits over the hitch and into the receiver to make up the difference.
Is this a safe way to go, or do I need to replace my WDH?
If it really is worth the money difference (to replace WDH ~$?? instead of using the adapter ~$30) - can't I just replace the part of the WDH that goes into the receiver and not have to replace the entire thing? It's going to have to be reconfigured/adjusted/setup anyway for the new truck anyway.
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
  • rockhillmanor wrote:
    Yes they make adapters for that. BUT I had draw-tite hitch and I bought a Reese adapter.
    They don't play well together.
    Reese made sure the holes did not line up with the draw-tite They made it just too long enough not to line up.:R
    I was so ticked. I took it to a frame shop and they measured and cut the adapter so the holes would line up.
    That's interesting, because Reese, Draw-Tite, Hidden Hitch, Fulton, Tow Power, and a few other brand names that I don't remember off hand, are all part of the same company. Alot of Reese and Draw-Tite's receiver hitches for the same applications are the same part, with different names on them...
  • My Chev truck is the same. It came with a sleeve or adapter that fits the receiver perfectly. I am sure you can order one on Amazon.
  • I have the same hitch in my 2014 Ram. I tried to find a 2.5 inch shank that dropped enough, but couldn't find one. I used the adapter, but it still had some slop in it... the sleeve had some slop, and the shank in the sleeve had slop as well (double slop). so I just had a local truck accessory shop weld the adapter in. Cost me like $25 bucks and it's all nice and snug.
    Mike
  • I am guessing the previous owner took the adapter out or lost it on the road. My F350 has the same configuration. The sleeve/ adapter just slides into the receiver. The only thing that holds it in is the pin that holds the hitch. Forget to put the pin in and the adapter can fall out.
  • Yes they make adapters for that. BUT I had draw-tite hitch and I bought a Reese adapter.
  • That's what the adapter is for, why would you think there's a problem?
  • I think they sell a adapter that fits inside that 2 1/2 inch hitch to fit 2 inch receiver, I know I have seen one.
  • Yes and yes.
    Yes, you can get the adapter sleeve (truck usually comes with one).
    Yes, you can change the shank to one that is the right size so you don't need an adapter.
  • rhagfo's avatar
    rhagfo
    Explorer III
    What you have an issue with a little slop??? :B
    Two options, get a correct sized shank, or the 2" to 2.5" adapter.
Looking for advice before your next adventure? Look no further.25,158 PostsLatest Activity: Jul 30, 2025
