Set up my TT for second time, turn on propane up front tanks but no propane anywhere in TT...did I forget to turn something on? I filled tank last week
All good advice. Start at the tanks checking your connection, valve on slowly, if multiple tanks make sure you are pulling from the correct tank (check the indicator on the regulator), Properly charged battery, make multiple attempts at lighting the stove to ensure air is forced from the lines.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
